Getting Freeview for WMC7
5 Dec 2008
Kent
Ok, I'm a bit of a noob at this kind of thing.
I am moving into a bedsit so would like Freeview TV on my PC.
Are there any guides to doing this on Media Centre for Windows 7?
I have saved a TV tuner from my old PC (about 5 years old now). Everything is in boxes so may take me a while to get it. Would it be worth buying a new one anyway due to it's age?
Would I be right in thinking that I plug a Freeview box into the TV Tuner and configure it all on WMC? I also won't have the internet at the new place. Is that a problem?
Thanks.
As long as the TV tuner has DVB-T rather than old analogue tuners it should work with WMC. If it doesn't have DVB-T then grab a new one. This is of course assuming that analogue transmissions are now switched off in your area. The card will need an aerial of it's own really.
Once installed WMC should pick it up as a tuner and allow you to search for channels.
WMC will want to connect to the internet but I can't remember what it actually gets from it so it might not be a required part.
Running a freeview box into the TV tuner is really not necessary as all it would do is see a video feed and would give none of the scheduling and recording functions you would normally get. WMC is pretty nice in that you can set a program to record in the middle of the night and it'll wake the PC from low power sleep to record it.
Just install the driver for the video card, then configure tv settings through WMC. It should do it all for you as long as the signal's strong enough.
Just to add it gets the 'Guide' (TV guide) from the internet. Allows easy recordings. Not sure how you would record without it, probably manually specifying time.
Wow tv tuners are expensive. I will look for my old one as I think it'll be perfect and I have an aerial for it too. When I find it, I will post a photo of it on here to double check with you.
Thanks.
Thanks.
The cheapest I saw on ocuk was £20. Not sure of it's capabilities though. Expect to pay £100+ for HD dual tuner cards and considerably less for dual/quad tuner SD cards.
Me too, how do people survive without internet, that was part of the criteria for the location of my house lol
Lol I know. It's terrible. Hopefully I can get the Internet when I get a proper job but at the moment, I have just graduated from uni and am working at Burger King.
I have a 3 mobile broadband dongle which is pay as you go which I can use every now and then.
*bump*
Ok, I'm moved in. I haven't got the TV Tuner yet but was wondering if it'll work. My landlord said that the house currently doesn't have an aerial.
Will the TV Tuner be able to pick up anything?
Thanks.
*bump*
Thanks.
i get 100+ channels with my tiny matchstick Ariel that came with the card,
Finally found the card. I can't find any way of identifying it so would anyone be able to tell if it will do the job from these photos?
That's not a TV tuner card. That is a PCI wireless network card. You can tell by the Link/Act LED along with the 2.4Ghz Omni antenna with RP-SMA connector.
At the very least a TV Tuner card will have a TV coaxial connector of some description.
