Is this computer chair worth it
With something like that, I think I would want to be able to inspect it first and check out the build quality etc.
Its most likely going to be the same as every generic Chinese made chair imported and re-badged as, as mentioned above, Cost co, Staples, office direct etc.
Is the cost co one Tublar steel or is it silver plastic ?
You never know if a chair's good till you've sat in it for a while. Some chairs look really comfy but feel like a bed of nails after an hour or so.
Sounds well cheap to me but being 6ft 5 I Have to test drive a chair before I buy it.
About a year ago I needed a chair urgently, standing up using the computer is difficult and unless your monitor has excellent viewing angles porn looks wrong, so I bought a £20 chair in Morrisons. The other week the stayie up bit stopped working and always bottoms out.
Not bad, a year or so out of a £20 chair. I shall buy a better one this time.
It's cheap enough to throw out if it is a melon at the end of the day so go for it.
If it does go bad then get into Staples, buy something there, they have offers running all the time. I got my one for £70 odd as it was half price.
It isn't leather, so will get sweaty in the summer. I have a leather seat which cost quite abit more but worth it in the long run.
I just went down to the local staples and tried out like 30 chairs to see how they felt. Those cheap deals on the bay are tempting but you have to wonder how long they'd last.
I'm pretty tempest by this myself.. the only issue with too cheap to be true chairs is the piston seems to fail and you find you have that sinking feeling.
If you do buy it it be interested in your findings!
Pretty sure I have that exact chair, had it just over a year now.
No complaints, it's nice and comfy, showing no real signs of wear yet.
Edit: Yep, it's the exact same chair, I bought it from a different seller for a little more though on the 6th of Jan 2011.
