PC restarting after boot
16 Feb 2012
Ok, was just playing a game, checked my desktop and tried to open web browser and the whole pc froze, nothing responded, so i done a hard reset.
After resetting i then tried to boot up my pc again, it then started to restart itself every 5-7 seconds, continuously until i turned the psu switch off.
Anybody know what this could be? Thanks.
EDIT: My 7950 is running at 55-60c under load, speedfan is showing this as overheating, is this a problem?
Is your system overclocked at all?
Try a CMOS reset, just in case.
Edit: Overcooked, LOL don't you love spell check :p
I've never touched overclocking on my pc, everything is at stock, i tried upping the core clock on my 7950 but reset it to 880 in the end.
Is it possible to list your full specs including PSU make and model.
Looking at your original post 60c is fine.
I5 2500k @ 3.3ghz, Gigabyte z68 UD4 B3 motherboard, powercolor 7950, 8gb ripjaw ddr3, 500gb seagate HDD, Thermaltake toughpower tx 675w PSU.
Finding out can be tricky, a CMOS reset and you could be up running without issue.
Its a case of trial and error to find out the cause of the issue.
If the CMOS reset does not work try single memory module, If your board is one I think it is you don't have on board GPU to test, do you have any possibilty of testing the parts in another system.
I have no idea how to do a CMOS reset. I will look it up.
It's pretty easy, its a case of either shorting two pins on the motherboard or removing the battery for 10 minutes.
The manual will show location of the pins to short.
I just read, after googling the CMOS, that these specific boards have a boot loop issue sometimes that requires a CMOS reset, you could have just worked this one out RJC, thanks i will give it a go.
Hopefully this will work :D, might be worth checking for a BIOS update which may resolve the issue.
