Hi all,
Been out of the hardware game for a while so I'm not sure about this. I bought this motherboard hoping to use a few of my older componants to keep my build costs cheaper. However I have just hit a potential snag, the PSU in the old machine was a 450W so I was hoping to use it and its a ATX v2.0 (it has the extra 4 pin motherboard connector).
The Manual did say it needs a :
"ATX 12 V Spec 2.0 or later"
so I did not bother ordering a new CPU. However now I have the motherboard it has an 8pin connector. Can I just get away with using the 4 pin? The manual also says:
"Do not to forget to connect the 8-pin EATX 12v power connector; otherwise, the system will not boot"
Do I need a new PSU? if so what revision of ATX?
Thanks in advance.
-Howard
Thanks in advance.
-Howard
