Cheap build for a friend
2 Jan 2011
Hey everyone I am just putting together a cheap build for my girlfriends brother he has £400 to spend and is this is £416 from OCUK so as close as!
Intel Core i3-2100 3.10GHz (Sandybridge)
Asus P8H61 PLUS Intel H61 Chipset (Socket 1155)
Zalman Z9 Plus Tower Case
OcUK Battle 550W
Asus HD 6770 1024MB
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz
OcUK 22x DVD±RW
I already have a HDD he can use and his parents said they will pay for windows 7. He just wants to play games like TF2, G-Mod and a bit of UT as well as doing his school work. I would put a better GPU in but the price is an issue also his screen only has a VGA in and he cannot afford a new one as well.
Just looking for a yay or ney on the build really and that I have covered everything and it will all work well together. I haven't ever built a lower spec machine.
Welcome to the forum :)
Slightly better spec:
Your basket
Product Name Qty Price Line Total
OcUK HD 6850 OC 1024MB GDDR5 PCI-Express Graphics Card £89.99
(£74.99) £89.99
(£74.99)
Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £89.99
(£74.99) £89.99
(£74.99)
Zalman Z9 Plus Tower Case with Fan Controller - Black £52.99
(£44.16) £52.99
(£44.16)
Gigabyte H61M-S2PV Intel H61 (Socket 1155) DDR3 Motherboard £46.99
(£39.16) £46.99
(£39.16)
OCZ ZS Series 550W '80 Plus Bronze' Power Supply £46.98
(£39.15) £46.98
(£39.15)
Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (BLS2CP4G3D1609DS1S00CEU) £31.99
(£26.66) £31.99
(£26.66)
OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £17.99
(£14.99) £17.99
(£14.99)
Sub Total : £314.10
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £12.50
VAT is being charged at 20.00% VAT : £65.32
Total : £391.92
You forgot the DVD ReWriter and a big no to the PSU.
I assume the OcUK HD 6850 is still the Asus card and it's currently £10 cheaper.
The Crucial Ballistix RAM is £12 cheaper.
+1 for RJC's spec, you will really struggle to do any better for that budget
Also just to emphasise - the "OCUK" brand PSUs are low quality units (Powercools afaik) only to be considered if you are running a low-end, low power usage computer. They are not suited for a gaming machine like this one, since the CPU and GPU will draw significant ammounts of power when under load playing games - you wouldn't want to trust such a PSU to that task.
