Are you a Trekkie and do you like sleeping to background noise?
I think I remember the producers of TNG acknowledging that you cannot hear sounds in outer space (which means all the external shots of space battles should have been silent) but of course that wouldnt have made for good tv (no photon torpedo launch sounds..wot!) so they rolled with it.
Depends where the microphone is.
I have never seen star trek but I quite like that sound :D
Since when could youtube videos be 24 hours long though :eek:.
How did the crew sleep?!
24th Century medication.
Awww yea, everyone's happy and high, except Lon Suder.
On the side, I do sleep to background noise, mainly a fan, or PC because of tinnitus, thunder-storm ones are nice and I can see why this is, any general subtle noise is.
Low-pass filtered pink noise, have to use that for a uni project set on a spaceship :p
Not great for a sleep aid though as it'll do a poor job of masking most distracting sounds owing to its lack of any higher frequency content, voices and creaks, etc will cut straight through this. A fan is better, and for tinitus, an out of tune radio (white noise) can work.
I found the thunderstorms in rainymoods a bit too loud for trying to sleep to once you had the drone of the rain set at a realistic level. Nice though.
A weapon large enough could create its own atmospheric shockwave temporarily ? :D
Years ago I knew someone who'd leave on Radio One AM on very low, back when they cut it off at midnight
Low level ambient noises or very bassy music relate to our earliest sounds heard while sleeping,etc waiting to be born, hence a subconsciously comforting effect
Dr.EM said:
A fan is better,....
Yea I actually have a fan in the bedroom - a small desk one tucked into the corner facing away into the wall. Its covered in an old shirt to there is zero airflow (motor cover is not covered of course). Its rammed against the cupboard so I get a nice loud hum.
They can be relaxing true, but if your problem is being a light sleeper and woken easily by extraneous sound, they aren't ideal.
EDIT: With the fan, I do the same though don't bother covering it. Pointing into a corner helps create a diffuse sound field making it less ditracting. I put it near the door as that is where other noise is likely to come from.
*51 1/3 hours of numa numa*
i call your 51 hours of numa numa and raise you 100 hours of nyan cat
____??____?????????
____??____??|::::::^???^
____??____??|:::::|??????|
____??____???O--O-O--O ?
*edit*
listening to that rain thing for a long time makes me want to pee :rolleyes:
This is awesome!! Gonna listen to this on my mp3 player on my next flight and pretend it's Enterprise! Should help me sleep and drown out loud babies :/
Surprisingly, all captain apart from the Quantum Leaper and Janeway, actually she wasnt bad, where awesome, great casting really to get them all so good
