True. Where about on the board does the AC'97 go? I already have audio plugged in to the board?
The cable has two plugs right? (HD audio and AC97) use the HD audio and just leave the AC97 hanging.
but where do I put the red sata wire to connect the front panal buttons?
Installing windows now just formatted the drive, do I also format the facory image?
I've set the multiplier to 44x but CPU-Z says I'm on 16x and @1.6MHz?
Ok, just downloaded Prime95. Never used it before, how do I see the CPU speed from it, sorry lol
), I can set these all to say 45X and that gives 4.5GHz when the CPU needs it, or I can disable the Turboboost with the option directly above, then set the CPU clock ratio to 45X and thats 4.5GHz all the time.
