32GB of portable storage is a HUGE amount for the compact size you will be carrying it in. The choice is yours if you want the storage with an extra safe aircraft-grade aluminum housing is waterproof to 200 meters, or a standard enclosure
Corsair Flash Survivor® 32GB USB3.0 Flash Drive (CMFSV3-32GB) @ £32.99 inc VAT
Your files are important — that's why you're taking them with you. Flash Survivor USB 3.0 helps keep them safe. The anodized, aircraft-grade aluminum housing is waterproof to 200 meters, vibration-resistant, and shock-resistant.
- Capacity: 32GB
- Read: 80MB/s
- Write: 40MB/s
- Interface: USB3.0
- Warranty: 5 Years
Only £32.99 inc VAT.
ORDER NOW
Corsair Flash Voyager 32GB USB3.0 Flash Drive (CMFVY3S-32GB) @ £25.98 inc VAT
"Get faster read speeds and rugged reliability with the Corsair Flash Voyager USB 3.0 flash drive. USB 3.0 read speeds let you access movies, pictures and large files up to 4x faster than traditional USB 2.0 drives and the durable rubber design is water resistant and shockproof to keep your data safe.
Fast – Access videos, pictures and large files up to 4x faster read speeds than traditional USB 2.0 drives
Durable – Corsair's proprietary all-rubber housing is extremely durable, water resistant and drop-tested for worry-free transport of your valuable data.
Shock Proof – Solid state storage makes Flash Voyager drives virtual shock proof.
Convenient – Just plug it in and go! Works with Windows, Mac OS X and even Linux without drivers.
Compatible – Designed for USB 3.0, backward compatible with USB 2.0
Backed by Corsair – A respected name with a passion for quality and customer service.
- Fast USB 3.0 connectivity;
- Durable rubber housing;
- Water resistant;
- Shock proof;
- 5 Year Manufacturer Warranty;
Only £25.98 inc VAT.
ORDER NOW
- Capacity: 32GB
- Read: 80MB/s
- Write: 40MB/s
- Interface: USB3.0
- Warranty: 5 Years
ORDER NOW
- Water resistant;
- Shock proof;
ORDER NOW
