Very interested in the new/updated Silver Arrow. Does anyone know when this will be available in the UK?
Seen it listed on a european site at €64.99.
http://www.thermalright.com/products/index.php?act=data&cat_id=37&id=189
Not to keen on the new fan colour.
Special features:
8 X 6mm sintered heat-pipes effectively takes away excessive heat from the CPU when overclocked, Nickel Plated heat-pipes, slower Oxidation and deterioration of the heat-pipes, provides longer period of Thermal conductivity.
Double fin design , each side with 154mm*120mm heat dissipation area, can be used with 14 or 15 cm fan ( fan clips included).
Special Arrow fin design, which allows cool air to pass through and take heat away rapidly, effectively provide cooling for the cpu.
Support Multiple-Platforms. Can be used on Socket 2011/1366/1155/1156/775 Platform, and AM2/AM2+/AM3/AM3+/FM1 Sockets.
Including TY-150&TY-141 Ultra low noise PWM fans and PWM Y-Cable. With the compatibility of up to 3 fans maximum.
Technical Spec:
Cooler Dimension: Length 155mm x Width 105mm x Height 165mm (without fans) 170mm x Width 130mm x 170mm (with both TY-141 and TY-150 fan installed)
Cooler weight: 1124g (including two Fan, without mounting brackets)
Heat-pipe: 6mm Sintered Heat-pipe*8 units
Cooler Base Material: C1100 Pure Copper with Nickel Plating.
Fan Dimension:
TY-150 Length 170mm x Width 26.5mm x Height 150mm
TY-150 Fan Speed: 500~1100 RPM (PWM)
TY-150 noise level: 17~21dBA
Fan Airflow: 38~84CFM
TY-141 Length 170mm x Width 26.5mm x Height 150mm
TY-141 Fan Speed: 900~1300 RPM (PWM)
TY-141 Fan noise level: 21~25dBA
Fan Airflow: 28-74CFM
