Lost password on a Acer Asire one netbook (vista)
10 Jan 2009
Hi all, I have been asked to try and sort a friend of the families laptop out, which they cannot access due to a forgotten windows log-in password.
Is there anything that can be done? There is an option after you enter a in-correct password that prompts for you to insert removable media - USB flash, external hdd i think - but when I put in a usb drive nothing happens?
I know on my Samsung netbook there is a system restore / backup feature but cant see anything like that on boot up of the Acer.
With no cd drive I am stumped as to what can be done?
Thanks
Can you boot into safe mode? if you can, and if you can access CMD then I think there is something you can type into CMD to change the password, not sure if it works in safe mode but just a thought :)
wont work mate, I cant get into windows even in safe mode :(
Never had any luck mounting a bootable usb stick (2 minutes ago being no exception), and no access to a usb optical drive :(
any other options lol?
Difficult with no DVD Drive, suppose a USB one won't work either, with no drivers...
Can't think of anything yet! Oh, and are you the dtokez from MSUK? If so, i'm the RooBoonix from MSUK :p
Buy a DVD drive? they are very cheap, I think £22 inc a burner or less even still with just a reader.
Its a useful tool to have around.
yes mate, im from MSUk too :)
I think I will just have to buy a usb cd drive. The laptop has a windows code on a sticker, is there a way to use this?
There is no need for all that kinda stuff, boot the laptop into a command promt and type
net user (Username here) *
then it will ask you to type in a password and repeat it.
Job done password changed.
P.S. To get the command prompt I think you keep hitting F8 on boot up and it will
ask you what you wanna do, you want something like networking with command prompt.
I tried safe mode with command prompt but I still have to log into windows which I can't do :(
The password I am trying to retrieve is the only account on the machine
Why try and retrieve the password when you can just change it?
Surely its easier to change the password instead.
Lost Acer Aspire one Netbook Vista password
Friend, the USB flash drive you inserted to your computer cann't work if the password reset disk didn't create before you forgot password. But, you still can recover lost Acer Aspire one Netbook Vista password with this bootable blank USB disk to DIY a password reset disk. At the same time, you may need professional Windows Password Recovery Corporation software to help you!
Also, you can try to recover password via search engine, command prompt, other admin accounts, etc.
