best set up for £200-£250 ?? anyone
what games will i be able to play with this set up ? cheers
as my curent setup will play hardly anything games run so slowly you cannot play them is that down to the ram ?? sorry am new to pc"s trying to get to grips with whats what and what does what
Do you need a whole system or just the parts listed? This can run light games nothing graphics hungry. If you are looking for a full system then £250 isnt enough.
my current set up is amd athlon 64x2 5000+ , 2gig ddr2 , AB1S-RS690MKM motherboard,windows vista ult, also have Geforce6100pm-m2 motherboard but dont know if thats any good or better than the AB1S-RS690MKM ? help am not clued up on this Yet
the games i try to play are at the lowest setting and still dont play right
Are your drives SATA or IDE?
What case do you have?
What PSU do you have?
If you open up the case, it'll tell you on the side of the PSU the make/model/power rating.
Case doesn't matter terribly what is it, just whether its ATX or microATX
sata drive 160 gig
case ? dont know what kind it is
psu ? dont know what that is m8
Can you get a picture up of the inside of the case? does it take a ATX or MATX sized board?
There usually is a label on the PSU saying the make+model.
Do you have a SATA DVD drive?
i have a sata drive 160 gig
the power thing says colorsit switching power supply
atx12v p4, 350w in red writing
as for atx or matx dont know what that is ?
am a newbie
am a newbie
You need a new PSU then.
ATX/MATX is the form factor (size) of the motherboard.
Do you have a DVD drive? is it SATA also?
I.e uses a cable like this,
what size of psu do i need ?
For what I'm going to suggest about 450Watts,
YOUR BASKET
1 x amd llano a6-3670k 2.70ghz (socket fm1) apu processor (ad3670wngxbox) £89.99
1 x gigabyte ga-a75m-ud2h amd a75 (socket fm1) ddr3 micro atx motherboard £69.38
1 x xfx pro 450w core edition '80 plus bronze' power supply £45.98
1 x ocuk 22x dvd±rw sata rewriter (black) - oem £17.99
1 x kingston hyperx blu 4gb (2x2gb) ddr3 pc3-12800c9 1600mhz dual channel kit (khx1600c9ad3b1k2/4g) £17.99
total : £253.33 (includes shipping : £10.00).
but you need to find out,
1) do you have a sata dvd drive?
2) what operating system do you have?
2) what resolution is your monitor, what inputs can it take?
a quick google tells me your current motherboard is matx - http://www.neoseeker.com/resourcelink.html?rlid=153946
So the Spec above will fit.
