Best ROM for Desire HD?
5 Oct 2004
Notts
I've had my HD for 18 months an want to reset it and install a custom ROM.
I can figure out rooting it etc but don't know what ROM to install from the numerous available.
Also, I'd like to backup my WIFI passwords etc. Any info on an app to do that would be great :)
Hi. It really depends what sort of ROM you're looking for. Ultimately the best thing to do is to try 2 or 3 different ones out and see which one you like best!
If you want a ROM that is very similar to how your phone is at the moment, you should get a sense ROM.
Sense is basically HTC's own UI on their phones (on android phones, the UI is called the 'launcher')
Android Revolution has always been great, but actually I'd say the very best sense rom at the moment is one called SmartDroid.
Away from sense, you can look at cyanogenmod and miui. With MIUI builds, just pick one off XDA, there's not much difference between them.
With cyanogenmod, I'd recommend you look at IceColdSandwich.
Here's a link to the forum with all the roms:
http://forum.xda-developers.com/forumdisplay.php?f=765
Do they all offer better battery life and more customization etc?
YES! In terms of battery though, although you can underclock and undervolt the cpu on a rooted phone to save battery, most of the battery drain comes from your own personal useage and apps rather than the ROM or firmware of the phone.
Hi
I'm going to be rooting & flashing a custom ROM onto my friends Desire HD. But I'm confused by all the guides it doesn't seem as easy to root as it is on the SGS2.
The phone is Orange branded & as far as I know has the latest update available for Orange this will be Gingerbread 2.3.5 as far as I'm aware.
Now to the part that confuses me. Do I need to make a gold card to be able to root it? Or is there a 1 click program I can use? We will be using this custom ROM android revolution hd once I know how to root it.
What about this method http://www.htcdev.com/bootloader/ if I was to do that would I be able to flash CWM from ROM Manager?
Cheers
