First time build, advice/suggestions?
28 Feb 2012
Hi...
I'm looking to upgrade to a new computer and have taken the leap to go ahead and build one for the first time. After catching up with the current state of computers I've looked around and picked out the following spec for a gaming/music production high-ish end computer. I was wondering if anybody has any advice for a first time builder or has any suggestions regarding changing my proposed spec or any issues that may arise...
Case
Corsair Obsidian 800D
Motherboard
ASUS Maximus IV Extreme
Processor
Intel Quad Core i7-2700k
CPU Cooler
Corsair Hydro H80
Graphics Card
MSI Geforce 570GTX
Ram
Corsair Vengeance 16gb (2x8gb)
SSD
OCZ 120gb
HDD
Western Digital Caviar Black 1tb
Optical Drive
LG Blu Ray Rewriter
Power Supply
Corsair Modular HX1050w Silver
.. I hope I'm not forgetting anything...
Ahh... Yeah that would be kinda useful :P Shall Do...
Forgot to mention I would purchasing 64bit windows 7 professional, probably OEM version, if that's relevant. I was wondering also about thermal paste and whether that's included or has to be purchased separately?
I searched components and checked compatibility as much as I could so would like to be sure the parts would all work together and that none of the parts are going to have issues. Sorry to ask so much, I just want to be as sure as possible before purchasing and building.
Ahh... Good, was one of the more worrying things to me for some reason. Interesting... The Intel catches my eye, having looked through the thread. Thanks a lot :)
Do u intend to overclock this system at all? If not sticking with stock cooler would save you a bit of money. H80 sounds a tad overkill to me for first build.
I'm surprised no one here has suggested yet that you could swap out that i7 for an i5 as if the rig is mostly just for gaming/music production (which I'm guessing isn't more CPU demanding than gaming), then an i5 2500k is more than enough.
It's not something I've done before but was thinking about investigating it, and the graphics card is OCed to start with? Wanted to be sure it wouldn't have an issues keeping cool so maybe went a little overkill :L...
Erm.. I don't think it's much more but is more comparable to video editing than gaming, which the i7 gets recommended for over the i5 from what I gather.
Thanks for the replies :)
I've had my eye on the Asus maximus series, have had one before, and it was the only one that would fit the mid-tower cases in a reasonable price range. I looked at the spec and reviews and it seemed fine, wasn't sure whether it being mATX would make much of a negative impact.
Ah... Well it's capable of SLI which is the main expansion I was looking for and find it appeals to me, unsure of competing motherboards somewhat though I guess.
The 500R and 650D both support the larger ATX and eATX motherboards. So theres no need to drop down to the mATX sizes.
