So, we had an issue with one of our door locks recently. It was installed as part of a new build house and is still under warranty with the door supplier (IG Doors).
IG Doors sent out a locksmith to open the door and then replace the faulty lock.
However, as the door was locked closed at the time of failure, he had to drill the door (both sides) in order to hack the lock to open.
So, now we're left with the following holes (same holes inside and outside) in the door (under the handle but even so...):
My view is that I want the door replaced under the same warranty that the locks were replaced, the door company (and locksmith) is that the doors "integrity and security have not been compromised" as the holes are covered by the handle. Yet surely, if you can see the lock mechanism through the holes, then that can't be as strong as it was previously with the steel door skin covering the door.
I feel I'm in the right wanting the door replaced as it did not have these damage holes (covered or not) before the lock failed.
Is there any law / guidance that can help me in this quest? The door company is standing firm and won't currently replace the door.
Thanks,
Lee.
Thanks,
Lee.
