**** ANOTHER BEST UK PRICE, THIS TIME COOLERMASTER ****
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys,
I have managed to secure 114 units of the Coolermaster CM-690 II Lite at a great price. This unit is EOL as the USB3.0 version is available now. Anyway to celebrate I have lowered the price to damn near cost for pre-order. The stock arrives tomorrow. The price will be going up (somewhere between £56.99 and £69.99) once the stock has arrived so grab your self a bargain before they hit our warehouse tomorrow.
Cooler Master CM-690 II Lite Dominator Case - Black @ £56.99 inc VAT
The CM 690 II Lite raises the bar again, but with value for money, with practical improvements over the top-selling CM 690. The spacious mid-tower will keep enthusiasts happy with room for up to 3 vga cards, high-end CPU coolers, top or bottom mount water cooling radiator and 1.8"/2.5" drive adapter. It also features much improved airflow with oversized mesh and enough space for up to 10 fans. Maintenance will be a breeze with the tool-free drive bays, new cable management and CPU cooler retention hole.
- Dimensions: 214 x 511 x 528mm
- Motherboard Compatiblity: ATX, Micro-ATX, Mini-ITX
- Room for 120 x 240mm Radiator inside the top and bottom
- Cable management and CPU retaining holes for easy maintainence
- Support Tri-GFXs
- 4 x 5.25" Drive Bays
- 7 x 3.5" Drive Bays
- I/O Panel: USB2.0, 1 x eSATA, 2 x Audio
- Front Cooling: 1x 120 mm (17 dBA)
- Rear Cooling: 1x 120 mm (17 dBA)
- Top Cooling: 2 x 140 / 120 mm (optional)
- Bottom Cooling: 2 x 120 mm (optional)
- HDD Cage cooling: 1x 120 mm (optional)
Was £69.99 Inc. VAT
Only £56.99 inc VAT.
ORDER NOW
If i ordered now would i get it delivered via courier on sat? :S I aint sure if next day includes sat for dpd
P.S If they don't can u get me it for a sat please else ill feel gutted as i want this case =[
Next Day does not include Saturday (It is a Mon-Fri service). You have to select the Saturday option to get it on Saturday. :)
I just posted in CS now Doh! And theres a saturday option? Hold on why i go look at the order system i not seen for ages :)
Sure is, make sure you pick that if you want it for Saturday, otherwise if you pick the normal Next Day it will arrive on Monday. :)
