A card for 2560 x 1440 gaming.
30 Dec 2003
As title. Would a EVGA GeForce GTX 560 Ti 2GB be able to run games at that resolution.
I will be using my new setup for photoshop/design work. I pretty much have the rest of my system specked. Im just on the edge regarding this. Would it be wort spending more money now or possibly installing another 560 in the future?
I just want to make sure i can play some bad ass games on this when i want to. I was looking at Diablo 3. Would this card run it at max res? Or should i take the leap now and get the 7950.
One 7970 with simple CCC overclock will give average of 45fps in games with everything maxed out. Any more than that xfire 7970`s. So with a GTX 560 XFIRE THE SIMPLE ANSWER IS YES AND NO. You will have to sacrifice AA setting and some. At the moment only a 7970 xfire can max out at this res if you want 60fps that is. Unless you want to go tri-quadfire Nvidia. Going get jumped on now!!!!!!!!!!!!
One 7970 with simple CCC overclock will give average of 45fps in MOST games with everything maxed out. Any more than that xfire 7970`s. So with a GTX 560 XFIRE THE SIMPLE ANSWER IS YES AND NO. You will have to sacrifice AA setting and some. At the moment only a 7970 xfire can max out at this res if you want 60fps that is. Unless you want to go tri-quadfire Nvidia. Going get jumped on now!!!!!!!!!!!!
http://forums.overclockers.co.uk/showthread.php?t=18371895&highlight=username_zuludawn
Did i really just quote myself, well i drink more Bass a lot later than most of you!!!!!!
i use a 5870, although i may not be able to max all settings, but it can run on high for pretty much all games.
It depends on the game really. At 2560 x 1440 my 1.5GB 580 will max skyrim without any issues at all, but it struggles with BF3 which I usually run at medium.
