Dont think it makes much difference atall, aslong as you get good paste like MX-4, Thermalright Chillfactor, IC Diamond ect its just about how you apply the paste ond not which one you buy, probably a difference of less than 1 degrees between all the good thermal paste's, any other difference is probably just from the apllication.
What were you using before though? And IC 24c I do expect to be a degree or two better for the fact it costs so much
nope not the case.
I use IC Diamond 24 carat, dropped 3 degrees off my load temps if memory serves!, very good paste![]()
