is my cooler performing
6 Feb 2011
n ireland
i have an akasa venom to which i have added another fan for push pull. asrock extreme 3 gen3 mobo, 8g hyperx, i5 2500k. in my case i have 4 120mm intake fans an 2 120mm exahust fans.
i have overclocked my i5 to 4.5g with 1.245 vcore (in bios) 1.255 in cpuz, llc level 1, ppl 1.79v the rest on auto. after 10 runs of maximum intel burntest i am hitting a high core temp of 75c
afaik 75c is fine for a stress test but with a low vcore shud my cooler not be able to keep this a good bit cooler. i have reset the cooler 3 times now (grain of rice method) no change in temps, using mx-4 paste.
so do you think i have a hot chip or a crap cooler?
Thats higher than what I get with a Antec 920 and the Titan Fenrir I use to have.
What are you using to read the temps? I use realtemp as below, heres my results.
Titan Fenrir V2 @ 4.5GHz
Antec Kuhler 920 @ 4.5GHz in silent mode
Antec Kuhler 920 @ 4.5GHz in extreme mode
feels like its screwed down as far as the screws will go so i cud try a little washer to pack it down a lil bit further. cheers for that idea stulid ill have a go and report back at the weekend :)
Then it probably is tight enough.
Are all the fans in the case working together for a front to back flow?
intake 1 bottom 2 front and 1 side. exahust rear and rear top. used the same config to cool my q6600 @ 3.3g with an ocz vengance cooler.
I forgot to add, my results above are immediately after 10minutes with Prime95 stressing the CPU.
10mins of prime. would much rather have ur temps with the Fenrir, think i might look into getting a new cooler soon
I vote "crap cooler". I had a Venom Pico, and it just wasnt very good. I could only overclock to 4.2 before temps got too much, and then it was still hot.
I upgraded to a proper cooler and i can do 5Ghz.
The Venom looks better than the Venom Pico but still not the best.
what is ur proper cooler?
shudda looked at ur sig before asking that lol. im off to stand in the corner now :D
10 min prime @ 4.6GHz, NH D-14 with speed throttle cable fitted to fans and 3 Akasa Apache Super Silent 120mm - 4 Pin PWM fans in an Antec P180.
Room temp is 22.3 C.
new cooler getting ordered soon. im using 1.25v for 4.5g and @ 4.6g 1.3v ur getting similar temps. cheers for the replies fella's :)
