- 11 Sep 2009
- France, Alsace
tartiflette oui...
You should NOT have cheese in dauphinoise!!!!!!!!!!!!!!!
Is it okay to do these with double cream? Haven't got any single at home and fancy making these tonight![]()
I always make mine with double cream. See the video recipe I linked in one of the above posts.![]()
The way I do it is as follows:
Preheat the oven to around 180-200C
1. Rub butter and garlic (quite a lot of both as I like the garlic, and the garlic helps to curdle the cream) all over the dish.
2. Thinly slice potatoes.
3. Layer potatoes along bottom of dish so that you cannot see the bottome of it.
4. Add pour some cream so it *just* covers the potatoes - but you can just see them through the cream.
5. Add salt, pepper, and a dash of nutmeg
6. Next layer repeate 3-5
7. Top layer as the rest again just finishing with some salt and pepper a little nutmeg (you really don;'t need much, just a single grate really)
8. Couple of small nobs of butter (optional)
9. Place in the oven for about 45 mins.
The time can vary, as can the temperature of your oven depending on it's characteristics. You should get a nice golden top to the dauhphinoise and the cream thickens and becomes "cheesy".
However, if you use photos then make them appetising ones. Either that or use potatoesDo half photos and half celeriac
Going to use this recipe and let you know how I get on. Is 170c not too hot in a fan oven though? I don't want the cream to split
I was just going by the ovens I'm used to! However, you know your oven better than I do!
Fan oven I'd lower the tempI was just going by the ovens I'm used to! However, you know your oven better than I do!
Bonne chance et bonne appetit!![]()
. That's a source I'm prepared to trust
