- 15 Feb 2011
- Corby,UK
Hi guys, I recently bought a 600T and having few issues with temps.
Coming from a Antec 902 were cable management is not great decided go for the 600T for the looks and cable management.
Problem is that im running 2 x gtx480 and idle temps rised from mid 40`s on the Antec to around 55-60 on the 600T.
Im using stock fans part from rear exhaust a zalman 120mm white one.
Removed all HDD cages from frontand using only 1 near the psu, so intake should be fine.
Problem i think is the 2 gtx480 are so close together on the rampage II extreme, and with the hdd cage in front of psu + case power connectors placing second card on the 3rd slot is out of question it doesnt fit , even if i move the hdd cage card still its the case connectors on the motherboard.
So really just come and ask for some advice as my cards are hitting stupid temps on bf3 , 3dmark11 etc around 90+.
I have a fan profile setup on evga precision to help cooling but they just run hot and loud, and before you say i know its a gtx480 sli setup thats how they are.
So yeah any ideas on helping temps down?
Thanks in advance
Thanks in advance
