2 Mar 2012 at 11:57 #1 Sweetloaf Sweetloaf Soldato Joined 5 Mar 2004 Posts 6,399 Location Southport Anyone know a quick and easy program that will remove this in Windows 7? Combofix worked when it popped up in XP but doesn't work for 7. Cheers!
3 Mar 2012 at 16:33 #2 KIA KIA Man of Honour Joined 14 Nov 2004 Posts 13,865 Try Malwarebytes with latest definitions in safe mode.
3 Mar 2012 at 16:45 #3 Shadz Shadz Associate Joined 6 May 2010 Posts 1,003 Location Nottingham, UK I have removed this before off a work mates machine but had to look up on this as well and this is what i did: http://virusremovalhelps.com/help-windows-secure-kit-2011-virus-removal/ If you are going to do it this way then just be careful in the registry as things can look the same.
4 Mar 2012 at 17:20 #4 Sweetloaf Sweetloaf Soldato OP Joined 5 Mar 2004 Posts 6,399 Location Southport I dualboot XP and seven, if I run Combofix in XP will it scan the 7 installation and sort it? Cheers again
5 Mar 2012 at 10:59 #5 KIA KIA Man of Honour Joined 14 Nov 2004 Posts 13,865 Sweetloaf said: I dualboot XP and seven, if I run Combofix in XP will it scan the 7 installation and sort it? Click to expand... No. Forget combofix. The malware looks like it is easy to remove. See the two posts above your last for two possible solutions.
