the extra vram at that res would help more on the 7950
No, 1.5gb per card.Won't two GTX 480's make 3gb Vram?
480s overclock well too. Easy extra 100mhz on stock volts with no heat rise.
GTX 480 may seem like a good deal becausce they are cheap, but there is a reason they are cheap, it's old tech now, power hungry and hot.. The 1.5GB will limit it's performance at higher resolutions than 1080P especially games like BF3..
You might be better off with two HD 7870's in Xfire depending on their performance, or two x HD 7950's...
Yawn @ power hungry and hot. So are nearly all high end cards, especially when overclocked.
I'd rather have SLI any day. I'd rather lop a teste than run Crossfire ever again. As if AMD's drivers weren't bad enough on a single card without adding to the problem.
They're still ridiculously hot!
A GTX 480 with a windforce cooler is the same noise as a 6970 on stock!
7950s are not exactly cool either when overclocked and the reference cooler is dire, very loud just like all reference coolers once you crank up the voltage.
Honestly at this stage if you already have a single or SLi GTX480s Mattuk69, hold out. Don't upgrade now, it is the wrong time to do so. You want to be on a level playing field with both sides having released the bulk of their next generation cards.
I was holding out on the 69xx for the 7xxx. But if kepler is coming out in April i guess i can wait a little more. I just hope the price and performance won't be a let down.
