- 15 Feb 2012
No good with cables, no good with cameras... good job I can program
It looks better with the case closed
Unless you're planning to put in a couple of high-end GPUs, that Corsair PSU is overkill![]()
Future proofing![]()
It's actually quite tidy insideI'll get one together and you can criticise away
Heh, I still have a HX520 from 2006.I expect it'll outlast my current PC (though it's only got 2x 6pin PCI-E connectors since the 8pin standard didn't exist back then).
It looks better with the case closed![]()
Inspired by Jackson Pollock no doubt.![]()
I thought you were a programmer?![]()
Superpi isn't the best way to gauge performance increase for your work, that's all I'm getting at![]()
Anyway, stuff the work benefits, I'm having fun![]()
