7870 looks a very good card tbh and a sub 280 price tag would put it in just the right place.
http://www.tomshardware.com/reviews/radeon-hd-7870-review-benchmark,3148.html
We like the 7870’s more compact dimensions, but enthusiasts will be disappointed to learn about two notable omissions: a BIOS selector switch and dual CrossFire connectors. Unlike the Radeon HD 6900s, which scaled up to four cards in a CrossFire array, the Radeon HD 7870 and 7850 can only be used in pairs. Moreover, the lack of a backup firmware makes flashing the BIOS riskier.
Rotten sods. Seems they're putting caps on like Nvidia did with the 460 etc.
AMD did the same thing with previous generations as far as CrossFire is concerned.
With the 5 series only the 58xx and 5970 cards could use more than 2 GPU's in Crossfire.
With the 6 series only the 69xx cards could use more than 2 GPU's in Crossfire.
No they never.
You could trifire 5770's.
And 5750's.
It could be just me or the 7870 performs pretty close to the 7950...
Because of the 1GHZ clock.
But the shader difference quite a fair amount, diminishing returns on AMD's GCN architecture came ridiculously soon maybe?
I remember when £260 would be a top-end. now its mid range? sad tale of the pc games industry, there are not enough people buying them.
In 2003ish or whenever it was launched I got a FX5950 Ultra in a pricing error for $180. But I clearly remember it being a $450+ card.
new gen should mean same performance for lower cost
