Dirty O/C I7 960 @ 4GHZ?
3 Mar 2012
Hey OCS
This is my first post here but I am usually on Techsupportforum.:rolleyes:
But I feel this forum will know more about my issue I am having, My problem is I have had my computer built and working 100% stable for about 6 months now and I have managed to overclock my I7 960 to 4GHZ stable but I feel the v core and other such things may be a bit high. I essentially winged it to 4ghz and I think its producing too much heat and it may be a 'dirty' Overclock.
PC specs:
Motherboard: Asus Rampage Extreme III
CPU: Intel I7 960 @ 4GHZ (Liquid cooled)
RAM: 12GB Corsair Dominator GT @ 1926MHZ (1866 stock)
GPU: Two Nvidia geforce 480gtx in SLI (stock speeds but wouldnt mind OCing)
PSU: 1250W Enermax Revolution
As I said my old rig (q6600) was very easy to overclock but I have had no experience of I series overclocking so I am looking for some advice, check my settings make sure i am not doing anything wrong.
I would like to push it maybe a bit more to something like 4.5GHZ But my temps are:
Desktop:35 Degrees
Stress testing:67 Degrees
I hear I7's are good up to 80 degrees under load but that seems a tad to hot for me.
EDIT: updated to show my bios settings.
Code:
Target CPU Frequency 4000MHz
Target DRAM Frequency1925MHz
LN2 Mode: Disabled***
QPI Loadline Calibration: Enabled***
Sync Mode [Enabled]
AI Overclock Tuner [Manual]
OC From CPU level Up [i7-crazy-3.85g]
CPU Ratio Setting {25.0]
CPU Turbo Power Limit [Disabled]
>CPU Configuration----------------------------
CPU Ratio Setting [25.0]
C1E Support [disabled]
Hardware Prefetcher [Enabled]
Adjacent Cache Line Prefetcher [Enabled]
Intel(R) Virtualiyation Tech [Enabled]
CPU TM Function [enabled]
Execute Disable Bit [Enabled]
Intel(R) HT Technology [Enabled]
Active Processor Cores [All]
A20M [Disabled]
Intel(R) SpeedStep(TM) Tech [disabled]
Intel(R) C-STATE Tech [disabled]
C State package limit setting (not in my bios)
BCLK Frequency [160]
PCIE Frequency [100]
DRAM Frequency [1925]
UCLK Frequency [auto]
QPI Link Data Rate [auto]
Memory Configuration Protect [Disabled]
>DRAM Timing Control--------------------------
CAS# Latency 9 [9]
RAS# to CAS# Delay 9 [auto]
RAS# PRE Time 9 [auto]
RAS# ACT Time 24 [auto]
RAS# to RAS# Delay 7 [auto]
REF Cycle Time 98 [auto]
WRITE Recovery Time 14 [auto]
READ to PRE Time 8 [auto]
FOUR ACT WIN Time 28 [auto]
Back-To-BackCAS# Delay 0 [Auto]
Timing Mode 2N [auto]
Round Trip Latency on CHA 64 [AUTO]
Round Trip Latency on CHB 65 [AUTO]
Round Trip Latency on CHC 65 [AUTO]
WRITE To READ Delay(DD) 6 [Auto]
WRITE To READ Delay(DR) 6 [Auto]
WRITE To READ Delay(SR) 19 [Auto]
READ To WRITE Delay(DD) 10 [Auto]
READ To WRITE Delay(DR) 10 [Auto]
READ To WRITE Delay(SR) 10 [Auto]
READ To READ Delay(DD) 7 [Auto]
READ To READ Delay(DR) 6 [Auto]
READ To READ Delay(SR) 4 [Auto]
WRITE To WRITE Delay(DD) 7 [Auto]
WRITE To WRITE Delay(DR) 7 [Auto]
WRITE To WRITE Delay(SR) 4 [Auto]
CPU Differential Amplitude [Auto]
CPU Clock Skew [Auto]
IOH Clock Skew [Auto]
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode [T-Balanced]
PWR Volt. Control [Auto]
Load-Line Calibration [auto]
CPU Voltege OCP [Enabled]
CPU PWM Frequency [auto]
Extreme OV [Disabled]
Extreme OC [Auto]
CPU Voltage 1.429 [auto]
CPU PLL Voltage 1.812 [Auto]
QPI/DRAM Core Voltage 1.442 [1.48125]
DRAM Bus Voltage 1.654 [Auto]
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM DATA REF Voltage on CHB [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
DRAM DATA REF Voltage on CHC [Auto]
DRAM CTRL REF Voltage on CHC [Auto]
IOH Voltage 1.244 [Auto]
IOH PCIE Voltage 1.508 [Auto]
ICH Voltage 1.111 [Auto]
ICH PCIE Voltage [Auto]
---------- Spread Spectrum Control -----------
CPU Spread Spectrum [auto]
DRAM Spread Spectrum [auto]
But any help is good help.
Thanks,
Altec
I saw a review of the big water kit and couldn't help but think surely that can't work. The rad looks tiny and there is nowhere for the heat to go.
I would wait for someone who knows about this stuff but I think you could get better temps with a diffrent cooling solution
its about right imo,seems a lot of cpu voltage though for 4ghz,your 12gb or ram wont help,much easier to oc with 6gb
80c and below is fine for those chips they run hot,max i get is 79c @4.2ghz with thermolab baram air cooler
vCore of 1.41V for 'only' 4GHz seems too much. Mine does 4Ghz on 1.28v and 4.2Ghz on 1.35v. Screenie in sig if interested.
Suggest you drop the vcore a notch at a time at 4GHz and stress test for stability. Once instability noted up voltage by one notch and hey presto, max o/c on min volts! ;)
PS I don't think you will be reaching 4.5Ghz on the nehalem chip unless you are very lucky...
