Got everything but 8pin connected
Am having definate issues with this psu, but wasn't sure if everything should be lit up
Looks like your psu is faulty as there is no PG signal.
The PG or power good tells the motherboard that all is ok on the psu side and the motherboard can power up now else without the PG signal the motherboard will be stuck in a boot loop cause as it will continously reset the processor.
Prolly just leaky caps in the psu.
its also giving out a long high pitch beep which cant be good
sorry for the newbie question but was given the tester by a buddie and tbh i wasnt sure what the pg stood for
cheers again
