My last TV had a VGA connection but my new one does not
it's a Panasonic P50ST30
this seems to be a description of the connections I have
At the back there are three HDMI sockets, one of which is clearly marked as the Audio Return Channel (ARC) and there is also one HDMI socket at the side. Also at the back is a standard aerial socket, a LAN socket if you want to use a cable to connect the P46ST30B to the internet, a SCART connector, a component video input via RCA connectors, an analogue audio in, a digital audio out and a USB socket. At the side there is a CI (Common Interface) slot, a SD card slot, a headphone socket, a composite video in, an analogue audio in and another USB socket for use with an HDD. As is often the case the connectors at the back face outwards which might make it difficult to mount the P46ST30B flush with a wall.
I want to be able to play streamed media from my laptop, what would be best ( easiest ) way to do this, my laptop has VGA and S-Video
perfect picture quality is not essential but I would like sound
Thanks
Thanks
