Two new Gigabyte motherboards for the value conscious now stocked at OcUK!
20 Jul 2009
The bleak North East arm pit of Britain
Hello
A few value lines to make building that new PC that little bit cheaper! :)
Gigabyte GA-970A-DS3 (Socket AM3+) DDR3 Motherboard @ £59.99 inc VAT
The 970A-DS3 motherboard is designed to offer a stable, high-speed platform for delivering amazingly fast data transfer via the GIGABYTE 333 onboard acceleration technologies. Featuring the USB3.0 controller, AMD 900 series motherboards allow users to take advantage of super fast USB transfer rates of up to 5Gbps, delivering 10x faster data transfer compared to USB 2.0. Utilizing the industry's first Serial ATA Revision 3.0 solution via AMD SB950 chipset, GIGABYTE AMD 900 series motherboards offer native 6 ports of next generation high speed data storage devices support with data transfer speeds of up to 6 Gbps with RAID 0, 1, 5, 10. The AMD 900 series motherboards introduce a unique hardware design with lower resistance fuses for ensuring lower voltage drops and providing more stable and plentiful power delivery. All USB ports also benefit from a 3x power boost for better power delivery to power hungry USB devices.
• On/Off Charge Technology
• Get Ready for New Generation of 32nm AMD AM3+ CPU
• Supports next generation of 45nm AMD AM3 CPU
• SATA 6 Gbps Support
• USB 3.0 Support
Form Factor: ATX
Graphics Interface: PCIe 2.0 (x16)
CPU Socket: AM3+
SLI: No
QPI Speed: N/A
System Bus: 4800MT/s
Hybrid SLI: No
Chipset: AMD 970
Hybrid Crossfire: No
Memory Type: DDR3
Crossfire: No
Memory Channel: Dual
Water Cooled: No
Memory Type (ECC): Non-ECC
SATA: SATA III - 6Gb/s
Memory Type (R/U): Unbuffered
RAID: SATA
Memory Speed (Mhz): DDR3 - 1066, DDR3 - 1333, DDR3 - 1600, DDR3 - 1866, DDR3 - 2000(OC)
Expansion Slots: 2 x PCI (32 bit), 1 x PCIe 2.0 x16, 1 x PCIe 2.0 x16 (x4 Bandwidth), 3 x PCIe x1
Memory Capacity: 32GB
Internal I/O: 1 x 24pin (V), 1 x 4pin (V), 1 x FP Audio Header, 6 x SATA III - 6Gb/s, 1 x SPDIF-Out Header, 3 x USB 2.0 Header
Graphics On Board: No
Back Panel: 1 x 10/100/1000 (LAN), 1 x Line In, 1 x Line Out, 1 x Mic In, 1 x PS/2 Keyboard/Mouse Combo, 6 x USB 2.0, 2 x USB 3.0
Only £59.99 inc VAT.
ORDER NOW
Gigabyte H61MA-D3V Intel H61 (Socket 1155) DDR3 Motherboard @ £51.98 inc VAT
PCI Express Gen.3 Support
The GIGABYTE motherboard is fully configured to provide gamers with the latest Gen.3 PCI Express technology, delivering maximum data bandwidth for forthcoming discrete graphics cards.
* PCIe Gen. 3 is dependent on CPU and expansion card compatibility.
• SuperSpeed USB 3.0
• SATA 6 Gbps
• 3x USB Power Boost (for USB 3.0 ports only)
• Humidity Protection
• Electrostatic Protection
• Power Failure Protection
• High Temperature Protection
Manufacturer: Gigabyte
Graphics Connectors: D-Sub (VGA), DVI-D
Form Factor: Micro ATX
Graphics Interface: PCIe 3.0 (x16)
CPU Socket: 1155
SLI: No
QPI Speed: N/A
System Bus: N/A
Hybrid SLI: No
Chipset: Intel H61
Memory Type: DDR3
Crossfire: No
Water Cooled: No
SATA: SATA II - 3Gb/s
RAID: None
Memory Speed (Mhz): DDR3 - 1066, DDR3 - 1333, DDR3 - 800
Memory Capacity: 16GB
Internal I/O: 1 x 24pin (V), 1 x 4pin (V), 1 x FP Audio Header, 4 x SATA II - 3Gb/s, 2 x SATA III - 6Gb/s, 2 x USB 2.0 Header
Graphics On Board: Yes
Back Panel: 1 x 10/100/1000 (LAN), 1 x D-Sub, 1 x DVI-D, 1 x Line In, 1 x Line Out, 1 x Mic In, 1 x PS/2 Keyboard/Mouse Combo, 4 x USB 2.0, 2 x USB 3.0
Only £51.98 inc VAT.
ORDER NOW
Been looking for a new matx set up to replace my ageing Q6600. Any idea what the second board if like for clocking? Granted its not a board designed for it, but i have managed to get my Q6600 on 3.2, was hoping for a similar upgrade (on a 2500k)
