- 25 Sep 2009
- Billericay, UK
I'm looking at possibly setting up a water cooling loop for my next video card upgrade - a Radeon HD7950. For me my PC is only ever taxed when it's playing games and since even older CPU's are often fast enough with a mild overclock I don't see the point in water cooling the CPU when it's the VGA that does most of the work.
Anyway my case is a two year old Lian Li PC-50R which at the time was the dogs nuts of cases but now there are better mid tower cases but I don't want to spend another £140 on getting a new case. It has two 140mm fans in the top so I thought I might get a 240 rad for 140mm fans which would have been great as these 140mm fans are very quiet but I doubt I have enough space inside the case and would mean re-routing the 8 pin cable from behind the motherboard tray.
I thought about it some more and the only solution I came up with was to remove the hard drive cage completely and the two support plates and mounting the rad vertically. The next stage would be to get some circular brackets to brace the re against the other side of rad while fitting the pump underneath the reservoir.
(inside my case: I'll be removing the hard drive cage and putting the hard drive in the 5.25 bay)
Above the the parts I'm looking, I have no idea if these will all work together or not.
I was also curious about the rads that OCUk have on sale. Apart from the price is the EK-CoolStream RAD XTX much better then the EK-CoolStream RAD XT? If I got a thicker rad would I have to faster fans or could I use slower fans?
