Network Configuration
WAN IP Address xxxxxxxx
Duration D: 06 H: 23 M: 59 S: 58
Expires Sun Mar 11 23:10:05 2012
WAN Subnet Mask xxxxxxx
WAN Default Gateway xxxxxxxx
WAN Primary DNS xxxxxxxx
WAN Secondary DNS xxxxxxxxx
WAN Third DNS 0.0.0.0
It limits the power coming from the cab. If the power is too high it can cause problems. It was probably put there by the installation engineer for that reason.What does the 6db forward path attenuator do? There was one in back of my modem. I took it out and it seems to make no difference at all.
You could try but I dout it'd help. Why would BT be expensive to install? It cost me a whopping £0.
