- 3 Oct 2009
- Wales
Pint or more of water before bed, haven't had a hangover since doing that
How and why would a fry-up help?
Ace! I've never made it into someones signature before. Thanks for the recognition of my wonders.
[ASSE]Hinchy;21429761 said:I am yet to have a hangover, no matter how much I've had to drink by:
1. Taking 2x iberprofen with a pint of water before bed.
2. Repeating the action when waking up in the morning.
Due to the effects of alcholo on the boady.
According to studies, drinking about 250 milliliters of an alcoholic beverage causes the body to expel 800 to 1,000 milliliters of water; that's four times as much liquid lost as gained. This diuretic effect decreases as the alcohol in the bloodstream decreases, but the aftereffects help create a hangover
Headaches result from dehydration because the body's organs try to make up for their own water loss by stealing water from the brain, causing the brain to decrease in size and pull on the membranes that connect the brain to the skull, resulting in pain.
The frequent urination also expels salts and potassium that are necessary for proper nerve and muscle function; when sodium and potassium levels get too low, headaches, fatigue and nausea can result
Alcohol also breaks down the body's store of glycogen in the liver, turning the chemical into glucose and sending it out of the body in the urine. Lack of this key energy source is partly responsible for the weakness, fatigue and lack of coordination the next morning.
The increase in glutamine levels stimulates the brain while the drinker is trying to sleep, keeping them from reaching the deepest, most healing levels of slumber. This is a large contributor to the fatigue felt with a hangover, Severe glutamine rebound during a hangover also may be responsible for tremors, anxiety, restlessness and increased blood pressure.
Because alcohol is absorbed directly through the stomach, the cells that line the organ become irritated. Alcohol also promotes secretion of hydrochloric acid in the stomach, eventually causing the nerves to send a message to the brain that the stomach's contents are hurting the body and must be expelled through vomiting. The stomach's irritation may also be a factor in some of the other unpleasant symptoms of a hangover, such as diarrhea and lack of appetite.
