PCIe 3.0 Vs PCIe 2.0 - Will having pcie2.0 slow my PCI3.0 graphic card down?
24 Jul 2004
Hi all.
I recently purchased a new PC, unfortunately I bought a pcie2.0 motherboard, and looking at the back of my graphic card it sasy it's pcie3.0
Will I need to RMA or will it be ok?
Are there any disadvantages to using a pcie2 mobo with a 3.0 GFX?
Thank you.
You probably wouldn't notice the difference as I think that PCIe 2.0 bandwidth isn't maxed. And anyway you'll need an Ivybridge CPU to get PCIe 3.0 anyway
there are no gfx cards that i know of on the market that saturate pcie2 - your card is pcie3 compatible - that is all - so it will work perfectly with your board
(and how would an RMA help? :p)
