- 20 Oct 2002
- Derby
Thanks for sharing the link
How'd u get that >_>![]()
I couldnt possibly comment..
Look at my last post. It seems its Anandtech who fudged the launch numbers for SB regarding power consumption.
Now,I am happy again!!![]()
Actually,I had another thought - it is possible the power consumption figures in the Anandtech Core i7 2600K launch article might have been off. Disaster(for me) possibly averted.
I think you just fudged your reading of it. Its total system power consumption.
Sandy bridge launch used this:
http://www.anandtech.com/show/4083/...core-i7-2600k-i5-2500k-core-i3-2100-tested/14
Ivy bridge preview used this:
http://www.anandtech.com/show/5626/ivy-bridge-preview-core-i7-3770k/4
Which accounts for the difference in power consumption.
In their previous reviews the Core i5 2500K and Core i7 2600K had the same power consumption.
Look at the articles. The Anandtech launch article and the preview. Look at the relative positions of the Core i5 2500K and Core i7 2600K.
I don't know what your worrying about. At load this early Ivy Bridge draw 27 watts less and idles at the same wattage, surely even a SFF can handle 75 watts can't it (how small is small BTW? ITX, M-ATX?)? If you want lower then 75 watts then you need to look at getting an SSD an external optical drive and maybe lower voltage ram (grasping at straws here).
When is IB released,I'm getting impatient to build. Will the price of SB go down, or will they simply be replaced?
I have a stupid question - will the GPU performance increase make any difference if you are not using integrated graphics? What I mean is if you have a stand alone GPU installed when you are gaming will you just be using that stand alone GPU or the stand alone GPU + the integrated graphics to run the game?
That's what I suspected, thanksIn those circumstances the integrated GPU will make no difference as you won't be using it.
Will there be a 6 core Ivybridge?
You need to invest in the enthusiast platform if you want 6 or 8 cores. Ivybridge/Haswell will be 4 cores where the power draw is steadily reduced & the integrated GPU is steadily improved.
If you want CPU performance go SB-E -to IB-E & if you want better integrated graphics go Ivybridge - Haswell.
