Hi guys,
I’m planning on looking at a Mondeo Mk4 Petrol Titanium X this weekend, and just want to make sure I’m doing it all correctly before I end up shooting myself in the foot somehow.
I’ll be doing an HPI check beforehand and then will look over the car inside and out as thoroughly as possible, check VIN, drive and listen for funny noises, look for mayo, check all the electronics work, look through the history paperwork and all that.
If I come to the point of buying the car, do you think I should be looking in to buying any sort of third party warranty? The garage apparently offer ‘warranty packages’, but would these normally be worth the paper they’re printed on? I think the main thing I’m worrying about is if I buy it and the engine seizes on the way home or something, would I have any sort of rights to legitimately return it, or would I be left with the bill?
Also, assuming the car is all OK, and considering it’s a 2.0 Petrol rather than a smelly diesel with a turbo, DPF, DMF, HP fuel pump and HP injectors, would I be better off in the long term trying to get a decent warranty cover? Or just keep a stack of cash just in case instead?
Thanks!
Dave
Thanks!
Dave
