********* Shinobi XL Big Gaming Tower Cases - IN STOCK NOW! *************
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
BitFenix Shinobi XL Full Tower Gaming Case - Black @ £139.99 inc VAT
We've taken our battle-proven Shinobi design and expanded it, creating a roomy, feature-packed full tower enclosure that will not only turn heads, but take them clean off. The larger size enables you to outfit your Shinobi XL with the latest fear-inducing hardware, including XL-ATX motherboards and the longest graphics cards. Shinobi XL can accommodate up to two 360mm radiators, making it ideal for water cooling enthusiasts. Four SuperSpeed USB 3.0 ports and the all-new BitFenix SuperCharge™ port keep your peripherals and mobile devices ready for battle, while the BitFenix FlexCage™ hard disk rack adds to the Shinobi XL's nimbleness. With three included Spectre™ fans, tool-free drive locking, filtered intakes and signature BitFenix SofTouch™ Surface Treatment, Shinobi XL is the chassis you need when vengeance is not enough.
- Dimensions (HxWxD): 570 x 245 x 557mm (ATX Full Tower)
- Motherboard Sizes: Mini-ITX, mATX, ATX, XL-ATX
- 5.25” Drive Bays: x 5
- 3.5” Drive Bays: x 7
- 2.5” Drive Bays: x 8 (using 3.5" drive bays and 5.25" adapter)
- Cooling Front: 1 x 230mm (included), or 3 x 120mm (optional)
- Cooling Rear: 1 x 120mm (included), or 1 x 140mm (optional)
- Cooling Top: 2 x 230mm (x 1 included), or 3 x 120mm (optional)
- Cooling Bottom: 2 x 120mm (optional)
- PCI Slots: 9
- I/O: 1 x SuperChargeTM, 4 x USB 3.0, HD Audio
- Power Supply: PS2 ATX (bottom, multi direction)
- Extras: Superior watercooling support, FlexCage™, SofTouch™ Surface Treatment, filtered intakes, tool-free drive locking
- Maximum CPU Cooler Height: 193mm
- Maximum Expansion Card Length: 377mm (with HDD cage) / 492mm (with HDD cage removed)
- Maximum MB Tray Clearance (rear): 34.5mm
Only £139.99 inc VAT.
ORDER NOW
I thought you was set on this case KD?
I even thought of you when I posted about the XL arriving!
and we have these :)
OcUK Tech Lab - V12 Watercooled Case - BitFenix Shinobi XL Full Tower - Black @ £420.98 inc VAT
Assembled by Expert OcUK Technical Staff, the V12 range of Pre-Watercooled cases brings you exceptional performance paired with incredible value for money!
The OcUK Watercooled Case range comes pre-assembled for your convenience. All of the difficulty of watercooling has been removed and allows you to enjoy the best performance without the hassle.
All of our pre-watercooled cases are built to order and come pre filled ready for you to build your dream system.
The system is shipped with Clear Mayhems Ultra Pure Fluid. If you prefer us to use a coloured fluid or specialist liquid, you can choose from a wide range
All you need to do is build your PC and install the waterblock which is just as easy to do as mounting any CPU cooler.
All leak testing and filling is carried out by our technical staff which means that the watercooling system is ready to use by you when it arrives. All that is required is for you to plug the pump and fans into your power supply.
PLEASE CHOOSE THE CORRECT MOUNTING BRACKET FOR YOUR CPU
- PCI Slots: 9
Component List:
1X BitFenix Shinobi XL Full Tower Gaming Case - Black
The brand new king of watercooling cases offering excetional hardware layout options and space for expansion, this case is futureproof to the next level!
1X Hardware Labs Black ICE SR-1 360 Radiator
Ultra high air flow and innovative built in shroud design offers uncompromised performance that is second to none.
1X EK Supreme HF CPU Waterblock - Copper Plexi
The most popular waterblock on the planet, and for good reason. A mixture of market leading performance and superb build quality. It's called the 'Supreme' for a reason!
1X Alphacool Laing D5 Vario Pump 655
The Best watercooling pump on the market. Needs little introduction.
1X Alphacool HF D5 TOP - Black Acetal G1/4
The ultimate top for your pump offers even better performance as well as more mounting and connective possibilities
1X Phobya Single 5.25” Bay Reservoir
Single bay reservoir for installation into the 5.25" optical drive bay.
8X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Shining Silver Finish
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.
1X XSPC 7/16" ID [16/11mm] High Flex Hose - Clear
High quality watercooling tubing with a superb bend radius
3X Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin Fans
The most recognised performance fans for watercooling radiators.
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3
***NOTE***
Our Custom Watercooling Kits and Cases are configured in house by our technicians. We endeavour to keep stock of all items at all times.
Should an item be in short supply or unavailable it will be exchanged for a suitable alternative.
Custom Units can take 24 to 48 hours if assembly of a component is required.
Whilst we endeavour to keep watercooling stock levels high for our watercooling systems, there may be some occasions where stock shortages mean that there will be a delay in completing your order. If this is the case, then our sales team are able to suggest alternative components to allow your order to be completed.
Only £420.98 inc VAT.
ORDER NOW
I was xD I've even ordered one of the stealth covers...
But I want to do a lot of cutting into the side panels, and I'm not sure how hard it will be to colour match paint with the softouch front and top. Biggest thing putting me off at the moment, which is a bit of a pain.. More of a pain that I'd had the entire build planned out in my head, but now might have to go back to basics. I'll wait until the stealth drive arrives though to decide how hard it would be to colour match it.
Edit: think I've found a way around it, so this may now be the case for me :)
kd
Cracking price at £119.99, very severely tempted by this case. But need to see a few reviews first.
sweet. ive read in another forum that they got a windowed side-panel now hope the price is good as well
seen this review http://www.techpowerup.com/reviews/Bitfenix/Shinobi_XL/ as well
Seen that review just now. Looks pretty good, though cooling via the front intake would be a slight concern for me. Though i suppose a few 120mm fans in place of the 230mm could help with that. Something like silverstone air penetrators.
Yea cases with front like this worries me. Where are they sucking the air from?
If there are holes it must be tiny to preserve the looks
No holes on the front panel of the xl, just the thin mesh strips. As im currently running pretty hot gpu's in sli, airflow is very important. Something that is pretty good in my current Lian Li A70F. Due to it's mesh grills at the bottom.
Ill be sticking to air cooling for the time being. Alpenfohn k2 cooler. Gotta say, the space in the xl is very good. And could be made a lot tidier than in the pic above, with the use of some bitfenix alchemy cables.
My current layout below.
By removing a few of the hdd trays, this could help with airflow on the xl.
