- 28 Jan 2012
Hey all, my first foray into overclocking has seemingly gone well. I've managed to follow this video, super cool accent and all. Here are some numbers and questions:
My System:
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail
Asus P8Z68-V GEN3 Intel Z68 (Socket 1155) DDR3 Motherboard
XFX 850W XXX Edition Modular '80 Plus Silver' Power Supply
Kingston HyperX Genesis 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit
Akasa AK-CC4008HP01 Venom Voodoo CPU Cooler
Crucial RealSSD M4 256GB 2.5" SATA 6Gb/s Solid State Hard Drive
MSI GeForce GTX 560Ti OC Power Edition "448 Edition" OC Twin FrozR III 1280MB GDDR5 PCI-Express Graphics Card
I ran the basic Prime95 test for an hour and hit 91 degrees briefly on temps. Is that bad or good, should I be concerned about the nature of the cooling? Most of the time they stayed in the 80-85 range but died immediately to 50 when I stopped the test after an hour.
Speed stepping is turned on but doesn't seem to kick in now. It used to idle down to 1600MHz, now it's seemingly set to 4700 for good, even when not needed. This increases the idle temps from 30 to 40-45 degrees which seems like a waste, more than anything else. Can I re-enable speed stepping with the range to hit 4700?
I think the core voltage got to about 1.336v. Good? Bad? I don't think I'll ever stress my system as much as that hour did, but I realise that's the point
Also, as in the video, I set my RAM timing to 'auto'. Where does it report the RAM speed in CPU-Z (in a number that relates to the 1600~ numbers you see on the product itself)? Should I be looking to set or fine tune that as well?
So many questions, appreciate any answers.
My System:
