im using Kingston genesis gray playing up. is that 4.2ghz @ 1.144v?I left my ram at stock speed. OCing ram can be counterproductive. What ram are you using?
Your build is most likely fine, as the system works.
Go into your BIOS and set bus speed to 100.0 MHz and multiplier to 42. Leave the TPU switch on. This should give you an easy 4.2GHz OC. Download one of the many apps to keep an eye on your CPU temp.
If the overclock fails, your mobo will restore to the default settings automatically, and reboot at stock 3.3gig- it will stop and start a few times- don't touch the power switch!
Use a benchmark/ burn-in program to test for stability, and creep it up .1gig a time by increasing the CPU multiplier.
I am going to eventually oc manually I just wanted to see what the switch can give meI got my I7 up to 5Ghz on 1.4vcore, I stayed well clear of it! Manual overclocking all the way
I can't see bus speed or multiplyer in bios wonder if bclk @103.0 and by all cores 45 is the same?
1.144v is what bios is showing, will check while running intel burn test.Yes: bclk is the bus speed in MHz. Set it to 100. 'By all cores' is the multiplier- set it to 42.
It's unlikely your vcore will be as low as 1.144V- probably more like 1.30-1.33 at this sort of speed. As long as it stays below 1.42V...
Keep your RAM set at its stock speed and stock voltage for now- OCing memory doesn't make that much difference anyway, and you just run a higher risk of instability.
Yeah I noticed the f10 to save in the box to the right. Its set to 100 now, I just need to download an app that shows what speed the cpu is running cpuz gives me an error 5 and shows no cpu info
