xp product keys
because iv done it before and it works, on vista and on 7, hence why you get 2 discs with vista and 7 containing 32 and 64 bit, and one product key
Both Windows Vista and Windows 7 keys are valid for either 32Bit or 64bit installs :).
Depends entirely on what you bought. OEM licenses are tied to their respective "bit" versions.
The same is not true for Windows 7, where all licenses were both 32 and 64 bit (if the product was available in both).
indeed they are, just need to know if xp is the same
Again, no. They are completely different products.
Really? I've updated several machines using 32bit OEM Vista to 64bit Vista and have never once had any issue activating via the net.
Are you maybe mixing OEM keys with Retail media? (can't remember if Vista has separate OEM/retail media now)
iv tried retail and oem, and they have all worked, my own 7 key is off my dead hp laptop, i thought, might as well use it on my pc since the laptop was borked, from another persons point of view it isnt legitimate, but it activated so thats all im interested in, as for anyone saying, oh well thats wrong, you shouldnt do it, well..... you know what i dont care, iv spend a lot of money on that laptop, only to be refused it being fixed under warrantee so i used it, and activated my 64bit win 7, this xp one im interested in, is a legit key on a legit laptop, just the question of will it activate or not is what i need to know
It'll activate the (x)bit version it was intended for and not the other.
These 20-odd Lenovo ThinkCentre A57 9704-7CG's I have sat here will only install/activate 32-bit Vista Business, I've tried Vista Business 64-bit and it always fails.
Hmm there must be something special about the royalty oem keys then, will those machines not even phone activate 64 bit? Is the 32 bit installation/media what came pre-installed?
I have never had a machine fail to activate when going from 32 bit to 64 bit in vista or w7 and that is on many models of desktops/laptops.
If you install using the key on the COA instead of the oem master key + oem files from the original manufacturer disc or recovery partition then quite a lot of the time online activation will fail and you will have to do a phone activation which will work fine.
You know there are two versions of Vista Business? If you are installing without a key and choosing the wrong one it'll probably cause that issue.
Vista / Windows 7 keys activate both versions (x86 and x64)
Windows XP don't - x64 of Windows XP x64 was released much later (2005) than the 32 bit version where as the above were released at the same time.
M.
