I was going to post this in the virgin 50mb thread but wanted to warn any potential customers about the kind of issues you might expect if you happen to be in an area which is congested.
I have been posting on their forums for help on this issue for 4 months now and kind of response they give is utterly laughable. Basically admitting that there is nothing that they can do about the poor service.
Here is a sample reply
Hi sidxms,
The fault is currently being worked on by our design team who are trying to find the best solution for your area. There is no estimate at the moment as to how long this may take and any attempt to estimate would be pure speculation. This sort of work can require roadworks to access cables under roads however, so the fix date may be at the mercy of local planning constraints.
Upgrading to 50 or 100meg would leave you on the same cables and thus would not resolve your issues.
As my colleague stated, we are unable to discuss account or billing information on the forums. Therefore, you would need to call 150 from a Virgin Media landline or 0845 454 1111.
Sorry for any inconvenience caused.
Kind Regards,
Jason G.
Help & Support Forum Team
Please check their forums to see if your area has any problems before moving to virgin media. Since I'm in central london I should get fibre soon and will move.
Sample pings during times which I want to use the internet actually.
http://www.thinkbroadband.com/ping/share/665cc25c10e54f7b0ed6e5b2089092df-12-03-2012.html
Hi sidxms,
Kind Regards,
Jason G.
