It's there for me in the usual place under 3D Settings in the NVIDIA Control Panel ..Help can't find SLI option ??? in the Menu any more ?
Same problem as the last lot for me - no Surround Support :
No text for the option (although you can click where the text should be for the option).
You try and apply surround and nothing happens :S
Roll back (again) it is then !
edit Actually it wont roll back (keeps failing) - gonna have to do a cleaninstall with an older version
Great :|
since i updated to these drivers i am getting this happen to me ever so often:
has happened 3 times now..
unless its something else?
gone back to 295 drivers for now
Well, following Purgatory's lead (thanks) did a full uninstall through control panel, reboot and reinsatall and the option is there and have surround set back up again
Ill try with some BF3 later![]()
