Caporegime
- 7 Apr 2008
- Lorville - Hurston
OK, I've been been doing some more reading, and more headscratching. Please bear with me.
I was just watching another DigitalRev video - quite enjoy his style now, though it was a bit hard to get used to at first - and he compared the 550d to the 7d, as if it were the 7d's little brother.
The images he said were pretty much comparable, though the 7d requires more after touching due to the softness of its images.
Now that makes me think that the 7d would be wasted on me, and that if I were not able to afford the 5d mk2 with suitable high-quality lenses, I might as well get the 550d with the same quality of lens as if I got the 5d. The stuff that the 7d offers (bar the 8fps I'm not really sure what it actually does) wouldn't go far with me, I'd expect.
Now the other thing is that I don't understand what lenses work across both. The EF-S has a shorter distance between the lens and the sensor, meaning they will collide, but I wouldn't want to have to change lenses down the line if I went FF.
For example the 70-200mm 2.8 seems to fit the 550d, but something like the 17-40mm wouldn't? Or would it? Should I care about having lenses that work with crop and FF? Hnnng...![]()
EF-S lenses only work with crop bodies, not full frame bodies. the 7d is miles better then the 550d.
Better ISO, better camera features, better body build and handling, and far better AF system.
