Cooling Project underway with Aida 64 Logging.
21 Feb 2012
Blackpool. UK
Hi Guys,
I am taking my cooling to its final step this weekend so thought it may be of interest for folks to have a bit of a reference topic as to how a few things work out.
The system:
Case: Corsair Obsidian 800D
Mobo: Asus Maximus Extreme IV - Z
CPU: Intel Core i7-2600K @ 4.8ghz
GPU: 3 x Sapphire Radeon 7970's running standard clocks (for now)
RAM: 16GB of Corsair Vengeance 1866MHz
HDD: 2x OCZ Vertex 3 Sata 6 SSD
PSU: XFX Pro 1250w Black gamer Edition
Cooling & Monitoring
CPU Block: EK Supreme HF Plexi EN
Radiator: 1 x EK Coolstream XT 360mm Copper Fins - Single Circuit
Reservoir: XSPC Acrylic Dual 5.25 with pump inside
Pumps: Alphacool VPP655 - D5 Pump
Rad Fans: 3 x Scythe Gentle Typhoon 1850RPM - AP15s.
Case Fans: 3x Corsair 140mm fans.
Coolant: Feser Aqua - Ultra Pure Water
Ok,
So what I propose to do is as follows:
  1. I will run Aida64's system stability test for 10mins as it is now, get a screenshot and post it on here.
  2. I will install my new radiator and fans and repeat the test to see what the extra cooling area does for the CPU (if anything).
  3. I will install my EK waterblocks on the 7970's and again, repeat the exact same 10min test.
The first test is done and came out as follows.
As you can see, the CPU is being looked after very well with room ambients of 22C, and the 7970's core and VRM's are having a hell of a time, although its worth noting they never get quite that hot after an hour on battlefield, so god knows what Aida64 does to them!?.
The radiator being added tommorrow is a Phobya Extreme Supernova 1260.
The 4 x 200mm fans to be installed on it are the Cooler Master MegaFlow 200
If anyone has any usefull comments or suggestions I would love to hear them.
10 minutes? cant you run it longer?
Pointless really, the relevant parts stabilised at those temperatures a few minutes prior (It graphs too, so easy to tell)
Plus, I dont want those GPU's at 90deg for a few hours on end, especially when they are going under water tomorrow night. Unecessary risk.
Do not use "Feser Aqua - Ultra Pure Water" have you read on the bottle how high the acidty level is?
Quoted from there site:
The PH-Value is 2.0 – 3.0 and lies in the acid ph-range
