Just ordered a Gelid Icy Vision Rev 2....
29 Sep 2006
West Yorks
Will I get everything I need or will I need to buy some extra vrm heatsinks?
One reveiw says the supplied vrm heatsinks are incompatible.
http://www.gelidsolutions.com/products/index.php?lid=1&cid=17&id=52
INCLUDING:
- More Heatsinks for Ram & VRM
Thanks guys.
AWPC, slightly worried you saying that two vrm heatsinks are missing, hopefully I receive the correct amount. I have stripped the card to re-apply the thermal paste before so I'm familiar with it, so hopefully it will be less than two hours, all the same I won't rush things.
I'll do some before and after temps and noise levels if I don't get too excited and forget about it.
I will have it monday :)
I've got the original Icy Vision on my Gainward 470. I thought mine was a reference design, but I had real problems getting the VRM sinks to fit. Ended up cutting down some spare Enzotech mosfet sinks (which work perfectly).
