Caporegime
- 18 Oct 2002
Sorry, that is what I meant but, without the long explanation, due to the way the system works afaik, if you get distinction/grade 1 across your 120credits at lvl 3 then they contribute 240points to your 630 maximum, so the lowest possible score is 480 afaik. grade 2/3/4 effectively multiple the credits in that module by that amount so if you get a 30credit module at lvl 1 in a grade 2, it becomes 60 points, if you do this at lvl 3, it becomes 120points.
So you don't NEED 85% in every module, but you do need 85% in most modules and it quickly becomes pretty difficult to get a first if you rack up a couple grade 2's. IE two modules at grade 2 at lvl 3 and the lowest you can get is 600, one other grade 2 and you hit 630. Also you can get 95% in the TMA's and 84% in the exams and you'd get a grade 2 for that module.
I mean its not insanely unfair that you basically have to do excellently in lvl 3 modules, but its still much harsher than most uni's which have first's with generally much lower scores.
