Video Editing PC
20 Jan 2012
I made a thread last month saying I'd only have a budget of £400 or so if I decided to buy a Desktop if my upgrade to a Q6600 didn't work out and as expected it hasn't really.
However my budget is now £700 (now £1000) and I'll be buying it at the end of this month it's sole purpose is for video rendering with After Effects and maybe some live streaming which is a cpu eater apparently because of the encoding required.
I don't need it for anything else like gaming etc just from the knowledge I have the two most important aspects to the build are CPU and Ram (plenty of ram)
So I call on you guys to help me out here for a final build I'll be purchasing (don't need a monitor/keyboard or mouse)
So look forward to recommendations.
Thanks
For £700 you'll be able to get a lovely machine based around the 2600K. Remember NOT to buy a graphics card :D unless you need more than 2 displays
Something like this and add yourself a case .... I'm sure someone will come along to refine this
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - Retail £233.99
(£194.99) £233.99
(£194.99)
Gigabyte Z68X-UD3H-GEN3 Intel Z68 (Socket 1155) DDR3 Motherboard £122.98
(£102.48) £122.98
(£102.48)
Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) £77.99
(£64.99) £77.99
(£64.99)
Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT064M4SSD2) £69.98
(£58.32) £69.98
(£58.32)
XFX Pro 650W Core Edition '80 Plus Bronze' Power Supply £64.99
(£54.16) £64.99
(£54.16)
Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP4G3D1609DS1S00CEU) £31.19
(£25.99) £31.19
(£25.99)
Sub Total : £500.93
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.00
VAT is being charged at 20.00% VAT : £102.19
Total : £613.12
(£194.99) £233.99
(£194.99)
(£102.48) £122.98
(£102.48)
(£64.99) £77.99
(£64.99)
(£58.32) £69.98
(£58.32)
(£54.16) £64.99
(£54.16)
(£25.99) £31.19
(£25.99)
Sub Total : £500.93
DPD Next Day Parcel
Total : £613.12
Thanks for the build, I think I'd need a graphics card for some open gl stuff possibly but not sure how important it is though in all honesty. As the type of content I'm producing means I only really need to see the image preview on the timeline and stretch the video to get rid of black bars and then I pump out the video from there. I think for the most part something similar to what you've suggested just probably twice as much ram.
Yeah I looked into it quickly and the more ram you can add the better 16GB-24GB Ram is ideal to get after effects working at a super efficient rate in combination with the CPU thanks for the build
I can always add the GPU the month after :D
A lot of recommendations for the Genesis grey. If you've ever used them you'll find the XMP profile for 1600mhz is set at 1.65V - I've always had trouble with these sets trying to run them at lower voltages.
Seriously recommend the Ballistix that run at 1600 @ 1.5V without problems
+1 On this ... 16gb is getting to be a sweet spot for a 2600k
Thanks for all the builds guys.
Getting a general idea of what I should get now will definitely try and get 16GB of Ram or 24GB of ram if possible within my budget ? or is that pushing it.
Didn't they overclock very well?
But the board doesnt havent like 8-10+ VRM CPU phases (actually just 4) like better boards and monster heatsinks to cool them, it does around 4.5-4.6Ghz± safely according to reviews.
Then theres the CPU lottery, some overclock better than others.
That £36 could get a better case with multiple fans/features.
