- 5 Jun 2007
- extremes.spacious.indelible
Called a McLeod
I've had a google but theyre about 50 quid, anyone know of something similar or somewhere cheaper?
Dan
Weld it to a stick ?
Won't the wood burn?
Well a small run of tooling would cost about £50 anyway.
Cut one out of steel yourself and get somebody to weld it to a stick?
Apart from the, 'weld it to a stick' notion...
Who the **** has the capacity to easily cut and shape tools out of steel?
£51.00Anyone work with metal wanna give me a quote for one lol?![]()
get a sheet of steel and just bite through it until you have the design you want then one inch PUNCH it onto a broom handle. You total poof.
