Hi Guys
We are pleased to announce the expansion of our excellent range of Hardware Labs Black ICE Radiators. The Black ICE Radiator range has developed into one of the most formidable radiator brands on the planet.
Featuring innovative features and aggressive pricing, the quality of Hardware Labs products is never brought into question.
The unique features that separate HW Labs Radiators from the competition
HW Labs are used in all high end applications at OcUK for a good reason, they are proven and they work. With the expansion of our range, now is the best time to choose the best radiator on the planet for your system.
Hardware Labs Black Ice GT Stealth 120 Radiator @ £30.98 inc VAT
The GTS120 boasts of a radically redesigned Black Ice® core technology that maximizes heat transfer efficiency and maintains effectively the same compact profile of the Black Ice® Pro.
Features:
- Two-pass U-flow tank configuration.
- Custom MaxFin™ 25 micron Copper Splitter Fin Configuration utilizing 45% thinner fin material yielding up to 50% less pressure drop even with twice the fin density.
- Unique fin configuration eliminates intra-louver accumulation of dust particles for trouble free operation.
- Unprecedented Ultra-high 30 FPI (Fins Per Inch) fin density providing dramatically increased heat transfer surface area.
- Custom low-profile 19.0 x 1.2mm MaxFlow™ tubes with 15% more waterside surface area and 60% frontal area reduction for superior low air-resistance aerodynamics and lower internal flow requirements.
- Yields up to 20% more heat exchange capacity than the Black Ice® Pro in both Stealth or Performance modes.
- Achieves Black Ice® Xtreme level performance in stealth mode (low-noise/low-airflow conditions).
- M4 Threaded Screw Holes for easier mounting and greater adaptability.
- Now standard G 1/4" female threaded fittings.
- Full high-temper brass structural construction for weight reduction and superior corrosion resistance.
- High performance compact radiator compatible as an upgrade to the Black Ice® Pro and most 120mm form factor radiators.
- Uses 100% Non-corrosive water-solluble fluxing process.
- Fully RoHS compliant.
- Full electrostatic polyurethane painting finish for uniform coating with high temperature curing for increased finish durability.
- Renowned Black Ice® quality.
- Patent Pending Design
Only £30.98 inc VAT.
ORDER NOW
Hardware Labs Black ICE Radiator SR1 120 @ £44.99 inc VAT
The Black Ice SR1 120 takes ultra-stealth performance that silences the competition. Utilizing the new Black Ice SR-1 platform, the SR1-120 provides superior cooling using sub-1000rpm fans with performance scaling effectively up to 2000rpm. This gives PC enthusiasts an unprecedented option to run their systems at ultra-silent levels with additional heat exchange capacity in reserve.
• Two-pass u-flow configuration utilizing high-flow tubes for up to 40% increase in internal flow rates.
• Custom compressed core width to maximize airflow and enhance heat exchange.
• Optimized custom 9 FPI (Fins Per Inch) 45 micron copper maximized conductivity.
• Yields up to 30% more heat exchange capacity than the Black Ice® GTX in ultra-stealth operation (sub-1000rpm fan).
• Built-in 15mm deep plenum for equalized core air pressure distribution.
• M4 Threaded Screw Holes for easier mounting and greater adaptability.
• Standard G 1/4" female threaded fittings.
• Full high-temper brass structural construction for weight reduction and superior corrosion resistance.
• Fully RoHS compliant.*
• Full electrostatic polyurethane painting finish for uniform coating with high temperature curing for increased finish durability.
• Carbon Black Finish
• Renowned Black Ice® quality.
Only £44.99 inc VAT.
ORDER NOW
Hardware Labs Black ICE Radiator SR1 140 @ £48.98 inc VAT
The Black Ice® SR1 140 delivers true ultra-stealth performance that silences the competition. Utilizing the new Black Ice® SR-1 platform, the SR1-140 provides superior cooling using sub-1000rpm fans with performance scaling effectively up to 2000rpm. This gives PC enthusiasts an unprecedented option to run their systems at ultra-silent levels with additional heat exchange capacity in reserve.
Features:
• High performance compact radiator compatible as an upgrade to the Black Ice® Xtreme, Black Ice® GTX140 and most 140mm fan form factor radiators.
• Uses 100% Non-corrosive water-soluble fluxing process.
• Carbon Black Finish.
• Patent Pending Design.
Dimensions
Width 153 mm
Height 171 mm
Thickness 55.9 mm
Only £48.98 inc VAT.
ORDER NOW
Hardware Labs Black ICE GT Stealth 240 Radiator @ £38.78 inc VAT
The GTS240 boasts of a radically redesigned Black Ice® core technology that maximizes heat transfer efficiency and maintains effectively the same slender dual-fan profile of the Black Ice® Pro II.
Features:
Only £38.78 inc VAT.
ORDER NOW
Hardware Labs Black ICE SR-1 240 Radiator @ £69.98 inc VAT
The Black Ice® SR1-240 bridges the gap between ultra-stealth and extreme high performance allowing it to effectively utilize sub-1000 rpm fans and scale performance up to 2000rpm. Ultra-stealth operation with increased thermal capacity, and from the industry's standard bearer for quality and craftsmanship.
Features:
- Two-pass u-flow configuration utilizing high-flow tubes for up to 40% increase in internal flow rates.
- Custom compressed core width to maximize airflow and enhance heat exchange.
- Optimized custom 9 FPI (Fins Per Inch) 45 micron copper maximized conductivity.
- Yields up to 30% more heat exchange capacity than the Black Ice® GTX in ultra-stealth operation mode up to 2000rpm.
- Built-in 15mm deep plenum for equalized core air pressure distribution.
- Standard G 1/4" female threaded fittings.
- High performance compact radiator compatible as an upgrade to the Black Ice® Xtreme III, Black Ice® GTX240 and most 3x120mm fan form factor radiators.
- Uses 100% Non-corrosive water-soluble fluxing process.
- Carbon Black Finish.
- Patent Pending Design.
Only £69.98 inc VAT.
ORDER NOW
Hardware Labs Black ICE Radiator SR1 280 @ £69.98 inc VAT
The Black Ice® SR280 raises the benchmark for silent performance. The Black Ice® SR1-280 uses the same ultra-stealth optimized Black Ice® SR1 core design in a dual-140mm fan form factor, offering performance enthusiasts with an acoustically balanced yet scalable PC radiator platform.
Features
• Yields up to 30% more heat exchange capacity than the Black Ice® GTX280 in ultra-stealth operation (sub-1000rpm fans).
• High performance compact radiator compatible as an upgrade to the Black Ice® Xtreme II, Black Ice® GTX280 and most 2x140mm fan form factor radiators.
Dimensions
Width 153 mm
Height 316 mm
Thickness 55.9 mm
ORDER NOW
Hardware Labs Black ICE GT Stealth 360 Radiator @ £49.99 inc VAT
The Stealth series from Black Ice radiators is extremely thin in design but boasts impressive cooling performance. This is the newest generation of Black Ice radiators which were redesigned significantly. The concept is the same as in the Xtreme series, just in a thinner design which still allows outstanding cooling performance. Due to the use of extremely thin fins the fin density was increased significantly and therefore also the cooling capabilities of this radiator! This 360mm radiator for 3x120mm fans can be installed in virtually any, even very small cases. Despite its compact dimensions it has outstanding cooling capabilities! It is designed to cool complete Computer systems from CPU over VGA to Motherboard and HDDs. The Black Ice Stealth radiators are made from brass and are equipped with soldered copper fins. The build quality is outstanding, the whole radiator is coated with a black finish. The radiators are designed to provide high cooling performance even with slow-spinning fans.
- Material: Soldered copper fins, brass casing and chambers
- Dimensions: (L x W x H): 397 x 133 x 29.6mm
- Connection threads: 2x G 1/4"
- Fan installation with M4 threads (on both sides)
- Weight: approx. 865g
Only £49.99 inc VAT.
ORDER NOW
Hardware Labs Black ICE SR-1 360 Radiator @ £83.98 inc VAT
The Black Ice® SR1-360 bridges the gap between ultra-stealth and extreme high performance allowing it to effectively utilize sub-1000 rpm fans and scale performance up to 2000rpm. Ultra-stealth operation with increased thermal capacity, and from the industry's standard bearer for quality and craftsmanship.
Features:
- High performance compact radiator compatible as an upgrade to the Black Ice® Xtreme III, Black Ice® GTX360 and most 3x120mm fan form factor radiators.
Only £83.98 inc VAT.
ORDER NOW
Hardware Labs Black ICE Radiator SR1 420 @ £98.99 inc VAT
The Black Ice® SR1-420 remains true to its roots in offering case-mod professionals the highest quality triple fan form factor radiator based on Hardware Labs' silent revision platform. The Black Ice® SR1-420 bridges the gap between ultra-stealth and extreme high performance allowing it to effectively utilize sub-1000 rpm fans and scale performance up to 2000rpm. Ultra-stealth operation with increased thermal capacity, and from the industry's standard bearer for quality and craftsmanship.
Features
• Yields up to 30% more heat exchange capacity than the Black Ice® GTX in ultra-stealth operation mode up to 2000rpm.
• High performance compact radiator compatible as an upgrade to the Black Ice® Xtreme III, Black Ice® GTX420 and most 3x140mm fan form factor radiators.
Dimensions
Width 153 mm
Height 460 mm
Thickness 55.9 mm
Only £98.99 inc VAT.
ORDER NOW
Hardware Labs Black ICE SR-1 480 Radiator @ £96.98 inc VAT
The Black Ice® SR1-480 bridges the gap between ultra-stealth and extreme high performance allowing it to effectively utilize sub-1000 rpm fans and scale performance up to 2000rpm. Ultra-stealth operation with increased thermal capacity, and from the industry's standard bearer for quality and craftsmanship.
Features:
- High performance compact radiator compatible as an upgrade to the Black Ice® Xtreme III, Black Ice® GTX480 and most 4x120mm fan form factor radiators.
Only £96.98 inc VAT.
ORDER NOW
Hardware Labs Black ICE Radiator SR1 560 @ £118.99 inc VAT
The Black Ice® SR1 platform is the new PC radiator technology from Hardware Labs designed for ultra-low airflow applications. Black Ice® SR1 radiators feature a custom compressed core width utilizing streamlined 45 micron copper fins giving it unparalleled performance from sub-800rpm to 2000rpm fans and flow constricted systems.
Features
• High performance compact radiator compatible as an upgrade to the Black Ice® GTX560 and most 4x140mm fan form factor radiators.
Dimensions
Width 153 mm
Height 605 mm
Thickness 55.9 mm
Only £118.99 inc VAT.
ORDER NOW
- High quality polyurethane paint finish - the best finish of all watercooling radiators
- Built in 15mm Fan shround - evenly distributes the pressure from a fan and eliminates dead spots
- Uses water soluble flux which reduces the amount of time you spend cleaning the rad before use.
- Compressed core with low FPI meaning very slow fan speeds are required to obtain good cooling performance.
Features:
ORDER NOW
ORDER NOW
Features:
Dimensions
Width 153 mm
Height 171 mm
Thickness 55.9 mm
ORDER NOW
Features:
ORDER NOW
Features:
ORDER NOW
Features
Dimensions
Width 153 mm
Height 316 mm
Thickness 55.9 mm
ORDER NOW
ORDER NOW
Features:
ORDER NOW
Features
Dimensions
Width 153 mm
Height 460 mm
Thickness 55.9 mm
ORDER NOW
Features:
ORDER NOW
Features
Dimensions
Width 153 mm
Height 605 mm
Thickness 55.9 mm
ORDER NOW
