how do you copy and paste a basket from ur basket to the forums?
Make sure your screen is showing your basket, put a scanner on your desk, lay the screen on your scanner, scan it!
Print screen then go into paint, paste, and crop it.
Or just use windows snipping tool if you're using Windows 7.
Or just copy / paste the text.
Isn't it the simple task of getting a graphics card which does SLI and allowing a friend to do remote access on your computer, then using nvidias screen resolution checker to capture the basket ?
Add this to your favourites bar
Code:
javascript:(function(){var%20a=function(){};if(typeof%20MyLib=="undefined"){var%20b=["https://ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js","http://ocuk-shopping-cart-to-forum-converter.googlecode.com/git/ocuk.js"];var%20c=function(){if(b.length>0){var%20d=document.createElement("script");d.src=b.shift();document.body.appendChild(d);var%20e=false;d.onload=d.onreadystatechange=function(){if(!e&&(!this.readyState||this.readyState=="loaded"||this.readyState=="complete")){e=true;d.onload=d.onreadystatechange=null;c()}}}else{a()}};c()}else{a()}})()
Then on the basket page, hit the button, and a box will appear with the BBCode you can simply copy across :)
