Kitchen is next to garage & utility, the fridge is opposite the kitchen sink, only way to get water is to drill hole into garage and garage into utility....
I will have chilled water.. quite tempted to tap it into a keg of beer....
That. Is. Genius. If you work out how to do it, do post
What part was it, was this recent?
"backplate/fan, fridge evaporator, two heaters - 9705290e" thats what I have in my .txt file from the repair around november time
When I was searching for it, everywhere had it out of stock but since this, I've noticed the freezer is slightly warming up (the ice in the dispenser is melting a little and all sticking together and then refreezing, meaning it won't come out of the hole (ooeer!?)
so thats possibly another separate issue? Not sure if the parts I need deal with both the fridge and the freezer.
Basically in my fridge/freezer. I have: freezer on the left, fridge on the right. Inside the fridge is a set of three draws, luckily they are all staying chilled and have their own temperature controller. Its the top half (the shelves) that arent cooling and are staying at room temperature.
The other day I was struggling to close the draws so I took them out and there was ice all over the back of what looks like some kind of plastic radiator I guess? Which is odd I think in the fridge compartment for there to be ice! Since I cleared all of this ice off, the temperature gauge on the front now displays the temperature of the shelves accurately (12-14c depending on time of day, which is right as that half isnt cooling anymore) but inside the draws have a separate gauge that says "1c" and to the touch, it seems about right.. I set it to the lowest to make sure everything in there was chilling correctly!
The fridge sometimes cools right down, as if it sometimes decides it wants to work but for the most part its given up. It did used to make a very loud noise at times but thats since stopped. Which is great as it was driving the dog nuts in the night time, she chewed all my kitchen door frame as high as she can reach!
