The New Cases Gallery
Last picture:
Watercooled pc.. Ocd wiring.. by http://www.samcatchesides.com/, on Flickr
Not finished on the wiring yet (not neat enough), and the lighting is the next project... Full custom diy RGB led system... :D
The res mounting is temporary until its been redrained and refilled.. Tie wrap isnt really a great permanent solution.
And the Dynamat thats visible will be trimmed and removed so its not visible on the back of the other case half (even though you cant see it when the case is together) ...
i7 2600k
ati 6990
ASrock extreme 4 gen 3 mobo
16gb corsair dominator
200mm rad in front with push/pull 200mm fans
120mm rad in back with push/pull 120mm fans
200mm fan in roof
Lots of carbon bits, and lots of time spent hiding wires...
Full photoshoot soon, when I can be bothered to pop it into the studio.
Sam
I think I must get it Or Akasa Venom Toxic but I am stuck on what I want to get :(
Well the x-predator is a huge and i mean huge case it comes with 2 200mm fans one on top and front your can attach 4 120mm/140mm fans or another 200mm on the side and has 2 fan controllers that can control up to 6 fans and supports the new long graphic cards and the XL atx mother boards
i did pay a little extra for mine as i dident want to wait for it to come back in stock so i ended up paying £130 with for the build quality is actually really good for the price
hope i have helped you, if not now made it harder to decide which one to go for :D
Some shots of my system since I put a two 560 Ti's in it a couple of weeks ago.
As the shots show, the Gainward Phantom cooler doesn't leave much room between the bottom card and the PSU, hence the spot fan.
I like the K58 case, but as most would agree, am not so keen on the bare metal interior.
Days off next week, and after a bit of research, am finally going to overclock the i7. Well overdue, but will be my first foray into overclocking.
You may have just made it harder for me now :( but now I am thinking about leaning towards the x-predator.
Its got to be the orange x-predator or the yellow toxic.
If my brother gets the x-predator in white which I think he might be ill go the opposite (we are twins) and we dont like to be the same! lol
How cute are they cards!... seems that strange to see cards shorter than the width of a motherboard. Neat.
The same for, flame696's setup. Love these compact cases.
